Old Jan 6, 2007 | 06:43 PM
chxf's Avatar
chxf
Default Re: Check Engine Light - HELP
Originally Posted by TP Xfire
I have a 2004 Crossfire Coupe Limited (40k miles), and recently the Check Engine light has come on
Maybe your ECU needs an update. See this TSB for '04 models: https://www.crossfireforum.org/forum...ead.php?t=6506
if I turn off the car and try to start it back up it gives me trouble and won't turn over. [...] It starts just fine on cold starts.
Mind, that there is a kind of safety feature. If you turn off the engine you need to turn the key to the very end to be able to start the engine again. It's not enough to turn to ACC only and then back. It's a Mercedes thing.
