Old Jan 7, 2007 | 07:30 PM
alfdoc's Avatar
alfdoc
Default Re: Navigation doesn't work!
Could you send those instructions to me also ? I found the speed sensing wire at the amp {which is I believe is more of a garden hose green with a white stripe than a dark green with a white stripe as the wire diagrams calls it out as} but I can't find the reverse wire you told me about, also were did you get the female wire ends for the plug at the head unit
Thanks.
