You don't really need a link. The procedure is pretty obvious:
- Pop the rubber dust cap off the back of the lamp housing. (Low beams are on the outside).
- Disconnect the wiring harness from the lamp by grabbing the connector and pulling straight back.
- Un-latch the bulb retainer clip. (use a small mirror to look in the housing to see how it works if you can't figure it out by feel).
- Remove the bulb.
Reverse the procedure to install the new bulb.
