Originally Posted by nascarhq
i just replaced both the high and low with HALO xenon plasma blue 12v100w/170w, they are a cheap but cool upgrade that require no wiring mods $6.00 a pair on ebay.
100W?! A lamp with that high a wattage is going to eventually fry your wiring harness if it doesn't pop a fuse first! No to mention the heat from something like that will most likely start to melt the plastic bits in your headlight. I'd be very careful running those. I used to work at a dealer and I have seen what can happen first hand. Personally, I wouldn't go higher than 85W with an incandescent lamp.
If you want REALLY bright light, save your pennies and get the McCulloch HID kit. It's worth every penny you'll spend.
