Old Jan 12, 2007 | 01:35 PM
HDDP's Avatar
HDDP
Default Re: Ecu Tuning: Crossfire Ecu Tune! Ny/ct/pa/nj
Originally Posted by JP@SI
So there isn't a Crossfire 3.2L (non FI)?
SPECIFICATIONS
MODEL: Chrysler Crossfire Roadster
ENGINE: 3.2-liter V6
HORSEPOWER/TORQUE: 215 hp @ 5,700 rpm/229 lb.-ft. @ 3,000 rpm
http://www.theautochannel.com/news/2...03/147426.html
Let me double-check that those numbers are correct as far as gains - that was advans posting (I'm under the assumption that you're saying we can't chip a C320, basically).
No, you are correct with the base OEM numbers... but obviously you have never dyno'd a Crossfire, nor have you tuned one... It looks as though you are speculating... The naturally aspirated Crossfire only puts 170 -180 hp to the wheel... with TQ in the range of 200 - 220... Depending on the car...
So if you are advertising the aforementioned numbers, you are basing them on a hypothetical and ZERO actual information...
Don't come onto this forum and say you can add "X" amount of HP with your chip tuning until you have the data to back it up...
