Originally Posted by Maxwell
have you lowered your spring height with an Eibach kit?
Yes, and that's the source of the excessive camber in the rear. I'm hoping that since the stock setup wore the tires out on the outside, having more negative camber may serve to balance out the tire wear. There's slightly more camber in the front, but it's right on the edge of the spec.
