Old Jan 17, 2007 | 07:40 PM
GatorLCA's Avatar
GatorLCA
Default Re: Ride of the Month
I looked on vb.org for a Ride of the Month hack but it seems as thought there isn't one available. I mean I could probably write something simple but I don't have access to the forum I used to run (middle of integration to another server)to test it out but we could easily make a thread or make a section in the mean time to be sourced from a picture on the front page near the top, under the gallery pics.
It can be done, but if you need any help with doing it I can help out with my basic vB coding knowledge.
EDIT:
I actually found one that will work but it will need to be modified once per month to fit the links of the member to the gallery or to the thread in which the Ride is featured. So whoever has Admin rights to the server and all that jazz...look at this link. I'll try to modify it to our needs as "Ride of the Month" if this goes through.
http://www.vbulletin.org/forum/showt...norable+member
(non VB license owners will not be able to see what it looks like or DL the code unless I post it here).
