Old Jan 19, 2007 | 11:07 PM
Maxwell's Avatar
Maxwell
Default Re: my tune, my dyno, my story...
Originally Posted by 04Fire
x'ed because of you I MUST HAVE THIS DONE!! It sounds to good to be true, but I don't care anymore it needs to be done.
I'm just wondering a few things, anybody can answer:
1) Is it possible to get the traction control completely off via the ecu (when the button is pressed)?
2) I'm looking into having the evosport under drive pulley installed (shortly) and was wondering if you already have a tune for this set up, because I live 3,000 miles away it is rather difficult for me to stop by for a dyno/tune. Is there a dealer located on the east coast?
3) Now I know this is going to sound a little crazy but here it goes... Is it possible to get the ecu to tune its self to 93+ oct when the traction control is turned off (for that little extra hp)?
The traction control is completely turned off when you deactivate it. But the stability program is always on, so if you go outside the parameters of the on board g-meter it will also cut the engine or activate rear brakes similar to the traction control system.
