Old Jan 27, 2007 | 11:19 PM
DTMenace's Avatar
DTMenace
Default Re: Lost My Key!!! Someone Help!!!
GolferGirl: The super glue idea is the solution, but not the brand you would find at a local store. Find a hobby store that sells model trains and they will have a special super glue, known as "CA". This glue will work, with the best results and it will permit you to position the parts, before it becomes fused together. I've used the product in the past, on a Nissan fob, successfully. The repair has lasted 8 months, to date. Make sure you use the minimum amount, you do not want any additional glue to seep into the fob, otherwise you will not be able to change batteries in the future. The hobby store owner may assist in this matter...
Good Luck,
DT Menace
