Old Jan 29, 2007 | 04:08 PM
GatorLCA's Avatar
GatorLCA
Default Re: best head unit for the xfire
Originally Posted by raulito11
No problems with the amp...pretty straight forward installation, no need to re-wire speaker or amp...just make sure that you reverse the connections of the yellow and red wires (yellow to red and red to yellow). I had circuit city do the install for me since I've never done an installation before and don't have the tools for it...cost $120 for installation.
Buy the Head Unit from Crutchfield, they give you all the necessary tools to do the install. I never did a Stereo Install before but I did it on the Crossfire and it was pretty easy. If you can match up colored wire, splice and tape (or solder) wires together, it's a breeze. Should take a few hours but it's worth saving the $120.
Plus Crutchfield gives you free tech support over the phone if something happens.
You need to reverse the wires because the Red wire from the factory harness is the 12V Constant and the Yellow is the 12V Switch (or ACC) whereas most cars the Yellow wire is the 12V Constant and the Red is the 12V ACC.
