Old Feb 1, 2007 | 08:53 PM
intenseblu's Avatar
intenseblu
Default Re: Need your opinions?
the back look a tad small ... as in the tire should be fatter and spacers would need to be used to correct the offset ... a drop will make it look better as well ...
i had this issue when i got my 18" ADR's ... i needed a 25mm spacer for the rear to bring them out to the fender line nicely to show off the meaty 275 tire ... before that they looked like they were tucked far in the fender as if the car had air bags and could drop on the floor ...
there is a really good dealer on ebay for mercedes spacers ... made here in the US, machined out of a solid aluminum block, with hub centric ring ... doesn't get any better than that...
