Originally Posted by crossfiretech
The radio connector is pretty much the same on all newer german cars.Your local radio install place probably has the harness and antenna adapters in stock....mine did!
Yes, I know I can find the connector, people say that there is a connector for VW that works fine (Scosche VW01B or VW01).
Originally Posted by David Burns
SLK-320 has a Bose system, Crossfire has an Infinity system.
Actually the Crossfire has a Becker Head Unit, Infinity makes the amp and speakers I believe.
If you show any good radio install guy the back of your radio he should know what to give you.Your also going to need the removal keys to get it out.You might be better off having them do the swap for you.If your looking for one of us to track down all the part #'s for you....I don't think thats going to happen!
I will probably purchase the Scosche one so I don't need the part number/s, I just wanted to know if the wire colors were going to match what the VW connector says they are....for instance, if the VW connector has a red wire (and says its hot positive) when it mates with the Crossfire connector, will the wires really connect what should connect. I don't want things going to the wrong place if you know what I mean. Thats why I was hoping someone could post a diagram of the Crossfire connector and show what each pin is expecting. This would help me install the head unit myself. Thanks for all info, and any more anyone might have :lol:
