Originally Posted by Maxwell
I don't think there will be any gains made by upgrading the srt6 cams. They are designed for boost, so you can open the intake valve as much as you like but it will most likely give you the same power as stock boost cams. Since everything is under pressure there really is nothing to improve on an already optimized cam, but you could play with pistons. lower that compression a tad more maybe.
Or, you could install the Schrick Cams and a thicker head gasket... BINGO !
