Old Feb 15, 2007 | 08:57 PM
  #44 (permalink)
feets's Avatar
feets
Default Re: crossfire vs. s2000
Originally Posted by intenseblu
planting your foot all the way down in a SRT that’s modified to the level that mine is gives a feeling not even a SRT-6 can match... its not a linear soft accel of the SRT-6, the civilized speed demon it is... its a forceful shove you in your seat, hold on cause the tires are going from side to side, you are already doing 160
The SRT-6 certainly does have a very smooth and strong pull. The modded SRT-4 is generally much more aggressive in nature and not nearly as smooth due to the peaky power production.
You want smooth? How about 500+ ft/lbs at the wheels by 2,800 rpm? 700+ ft/lbs by 4,500 rpm and still climbing. That, my friend, is smooth. Forget down shifting. Just ease down on the throttle and watch the little Mustang slide backwards as the rpm builds.
Every now and then, owning a science project has it's benefits.
As for the Evo, one of the guys at work has a 2005 MR. It cost him more than my SRT and could not get around it until after he added software mods, swapped out the exhaust, and increased the boost. He's now run a 12.9 to my 13.2 at the same track.
