Originally Posted by TP Xfire
I have a 2004 Crossfire Coupe Limited (40k miles), and recently the Check Engine light has come on (after I filled up the tank). First thing I did was check the gas cap, it was fine, but the light is still on. I thought maybe it was poor quality Gas so I put some of the fuel cleaner in that tank and the next day the light actually went off. But it only stayed off for about 2 hours, and now it's back.
While the car is warm (after driving for 15 min or so), if I turn off the car and try to start it back up it gives me trouble and won't turn over. It take about 4 tries until it finally starts back up. It starts just fine on cold starts.
Other than that the car runs normal! Before I take it to the dealer to be fixed, does anyone have any advice or has anyone experienced this? And how much did it cost?
Thanks in advance for your help!
- TP
Did you get your car scanned by a dealer? let us know what sensor error is at fault.
I have heard of other cars with a pressure sensor near the tank would fail, but it could also be a hose connection at some port that blew off due to high pressure in the tank. I would need to look at the factory manual for a diagram and see where the vent hoses and ports are located.
