Originally Posted by jsisabella
I have one of those copy manuals also. I will take a look tomorrow and see if it has any wiring info for the pin configurations.
8) Hey, that would be great!! I was scouring the net recently to find the answer and came up with the following. Maybe you could see if this is correct. Its for the SLK but should maybe be for the Crossfire also :?:
Info below is from
http://www.slk32.com/pages/radioupgr...ioinstall.html
>>>>>>>>EDIT: Don't follow this!! CHECK MY NEXT POST BELOW>>>>
Wiring color codes on the Mercedes harness:
Brown = Ground
Pink w/ yellow stripe & green dots = 12v ignition
Gray w/ blue stripe = Illumination
Blue w/ white stripe = Amp turn on lead
Red w/ green stripe = 12v constant
Yellow w/ green stripe = ? (Unknown)
Green w/ white stripe = ? (Unknown)
Blue w/ red stripe = Left front negative
Blue = Left front positive
Yellow w/ brown stripe = Right front negative
Yellow = Right front positive
