Old Feb 21, 2007 | 09:04 PM
  #73 (permalink)
psuperti's Avatar
psuperti
Default Re: Twin Turbo News!!!
Originally Posted by RPM
Um, 3.8 S engine - please explain.
These are upgrade kits from startech:
The STARTECH high-performance brake system with six-piston aluminum fixed calipers and 355-mm vented and cross-drilled discs on the front axle and 300-mm discs with four-piston aluminum fixed calipers in rear guarantees maximum stopping power and endurance.
The coupe is normally powered by a 3.2-liter V6 engine with 218 hp / 160 kW. STARTECH offers four levels of tuning for the Crossfire. The STARTECH ST6 performance kit with two sport camshafts and custom valve springs increases power output of the six-cylinder to 233 hp / 171 kW. An added metal catalysts system and the STARTECH sport rear muffler turn this kit into the STARTECH ST6 S performance kit with 243 hp / 179 kW at 5,800 rpm.
STARTECH also offers the proven method of increasing performance by increasing displacement for the Crossfire. In addition to the STARTECH 3.8 increased-displacement engine with 280 hp / 206 kW STARTECH offers the STARTECH 3.8 S engine, which represents the top end of the STARTECH lineup.
A custom crankshaft with longer stroke, precision-balanced piston rods, larger pistons and an increased bore facilitate the displacement increase to 3.8 liters. In addition the cylinder heads are precision-machined and fitted with custom STARTECH camshafts. High-performance metal catalysts, a sport rear muffler and precise calibration of the engine electronics complete the extensive engine conversion.
The STARTECH 3.8 S increased-displacement engine runs silky smooth and produces low emissions, while at the same time delivering exceptional performance: Rated power output increases from standard 218 hp / 160 kW to 300 hp / 220 kW at 5,750 rpm. Even more important for increased driving fun is the improved elasticity through an increase in torque: The STARTECH 3.8 S engine produces a peak torque of 395 Nm.
Performance of the tuned coupe is on a correspondingly high level: Acceleration from 0 - 100 km/h takes just 5.9 seconds, top speed is 271 km/h.
The fully stainless-steel STARTECH sport rear muffler is also available without engine tuning.
6.1 liters displacement from eight cylinders, 426 hp / 313 kW maximum power output, a peak torque of 621 Nm, 0 - 100 km/h in 4.7 seconds and a top speed of 300 km/h: STARTECH offers an American muscle car made in Germany in the form of the STARTECH Coupe V8 6.1.
The engine bay of the new coupe turned out to be large enough to accommodate the STARTECH V8 6.1 increased-displacement engine, albeit after some modifications. Power is transferred to the rear axle via an electronically controlled five-speed automatic transmission and a custom-developed locking differential.
The STARTECH V8 6.1 engine delivers 426 hp / 313 kW at 5,400 rpm and produces a gigantic peak torque of 621 Nm at 4,100 rpm. Thus equipped the two-seater coupe turns into a purebred sports car with extreme performance potential: The STARTECH Coupe V8 6.1 takes just 4.7 seconds to accelerate from 0 - 100 km/h. Top speed is 300 km/h.
I better site this: http://www.startech.de/p13e.htm
