Xfire's Best Features
Hi Everyone. I think it would be cool to start a thread that lists some cool features that most people don't know our xfire's have. For future owners! Here is some I know. Everyone add the ones I missed!
Driver Convenience: Cabin Air Filtration System - Fresh Clean Filtered Air inside Cabin
- Also cuts down on cabin dust.
Driver Convenience: Recirculation Button - Prevents outside air (dust and odors) from entering your vehicles cabin. You can also use this feature to keep warming your cabin for 30 mins when it is cold outside.
Convenience: Locking Gas Door
Driver Convenience: Speed Sensitive Wipers - Wipers will change from normal mode to intermittent mode while stopped to prevent the wipers from going across a dry windshield.
Serviceability: Oil Level Sensor - Alerts you when the oil level is too high or low.
Serviceability: Anti Tow Away Alarm - When engaged if someone tries to tow the car the alarm will go off and the lights will start to flash.
Driver Convenience: Integrated Key Remote - The key and remote are one piece. The keys flips out of the remote like a switchblade.
Serviceability: Tire Pressure Monitoring System - A light will illuminate on the dash if the tire pressure is too low. Most people dont check this enough. It shouldn't replace your own checking but it helps.
Serviceability: Flexible Service System - Helps you keep track of when service is due and what service is due.
