Old Feb 22, 2007 | 02:48 AM
MMZ_TimeLord's Avatar
MMZ_TimeLord
Default Re: Xfire's Best Features
Automatic Transmission Program mode selector switch: The transmission is provided with a selector switch for Standard “S” and Winter/Wet “W” (snow and ice) program modes.
Driver Convenience: Telescoping Steering Wheel.
Serviceability: Top accessible oil filter element that is easily removed without mess.
Serviceability: Light Outage Indicator With the key in the ignition switch turned to the ON/RUN position, an indicator light comes on. It should go out when the engine is running. If the indicator light does not go out after starting the engine, or if it comes on while driving, it indicates a failure in the parking light, taillight, stoplight, or low beam headlight. The indicator light will come on when the exterior light fails. If a brake light fails, the light outage indicator will come on when applying the brake and stays on until the engine is turned off.
Safety - Electronic Stability Program (ESP): The ESP enhances directional control and reduces driving wheel spin of the vehicle under various driving conditions.
The ESP system corrects for over/understeering of the vehicle by applying brakes to the appropriate wheel. Engine torque is also limited. The ESP warning light, located in the instrument cluster, starts to flash as soon as the tires lose traction and the wheels begin to spin.
Convenience: Dual climate temperature controls.
Convenience: Heated seats.
Convenience: Dual 'one touch down' power windows.
Convenience: The HomeLink Universal Transceiver replaces up to three remote controls (hand-held transmitters) that operate devices such as garage door openers, motorized
gates, or home lighting. The transceiver triggers these devices at the push of a button. The transceiver operates off your vehicle’s battery and charging system: no batteries are needed.
Convenience: Umbrella Hook. Your Crossfire is equipped with an umbrella hook. This
feature is located behind and between the two seats, just above the map pocket.
Night Security Illumination: For added security when exiting the vehicle after driving with the exterior lights on, the lights will switch on again for approximately 30 seconds after closing the last door. The lights-on timing can be changed at your authorized dealer.
For those who wish to know more... you can download the owners manuals from this thread.
