I've seen on a few occasions, the tire light come on, if the pressure is low. This would be in the morning. After driving around for a few minutes, the heat will build up pressure and make it go out.
I believe the suggested PSI for front and rear is located on the drivers side door trim. Open the door and look.
Remember, the PSI ratings are for cold tires. Adjust when you haven't driven the car for a while.
If your tires are in range, then maybe you do have an issue with the sensor.
As for the oil pressure light? Scarry stuff. What does your electronic sensor say in the car? Have you checked the level with it? Maybe you are low!
