Old Feb 22, 2007 | 08:16 PM
BRappaport's Avatar
BRappaport
Default Re: Roadster Third Brake Light...Need Forum Expertise!
Originally Posted by Gwetoe
I also have a manual. It seems as though none of the electric devices on the car with the exception of the headlamps and dome light will work when the vehicle is not "turned on." The cigar lighter will not even function unless you turn the key.
That's correct...and the Horn does not work either with the engine off!
These are safety problems in my opinion. Example...you are sitting in your car at the mall with engine off...and someone doesn't see you when backing up...you blow your horn to stop them...Oh SH*T...no Horn!
