Originally Posted by FerrariVdub
I did check the oil myself and it seems to be fine, looks to be full where it should be.
THis damn tire light is killing me though I hope i put some air in and it goes away.
I was talking about the electronic level check, not with the dipstick.
As for the tires, use a tire pressure gauge. Don't add air if it doesn't need it! They could be over filled as it is. The tire pressure system is very sensative, it could come on even if you are a few pounds off. With temp changes, usage, it will shoot up or down as much as 10psi!
