Old Feb 24, 2007 | 09:26 PM
andrew's Avatar
andrew
-C-I-C-C-I Associate Member
Default Re: HOW-TO: Disable the Seatbelt Warning Chime
the easiest way to disable the chime:
begin by moving the drivers seat forward & up as high as possible... the wire is easier to access from the rear of the seat... it is clipped onto the far back side metal seat frame edge under the seat... held in place by 2 metal tab clips... release the clips and you will have nearly a foot of wire to work with. a flash light will aid... carefully cut back the plastic sheathing... 3 wires will be exposed... snip the brown wire and the chime has been eliminated w/o any side effects. tape the wires back up with electrical tape and re-secure with the clips.
