Old Mar 1, 2007 | 09:38 PM
andrew's Avatar
andrew
-C-I-C-C-I Associate Member
Default Re: X-Fire Brake Dust Shields
Originally Posted by Texpar
So why do they not make dust?? what is wearing away if the pad is not? How much is it wearing the rotor? On my Charger I use an inexpensive non metallic pad and get nearly no dust from it. I think metallic pads are a big contributor to dust on rims and a lot of the dust is actually metal from the pads and rotors. So I just wonder about these pad you speak of... I will do a search on the threads here and learn!
the material used in 'dust-free' pads creates a light colored dust which doesn't show on the wheels. the softer the material equates to a shorter the life span and distributes a darker material/residue visible to the eye.
here is some general info from the manufacture...
Rotex Gold is the finest Kevlar metallic pad to date. It offers excellent stopping power, combining top-rated performance with a long service life. The friction material blends Kevlar with metallic soft steel wire and powdered sponge iron for maximum heat transfer, and silver virgin graphite for smooth quiet performance. This 60% metallic blend reduces vibration which causes squeal, and runs virtually dust free eliminating the common problem of "black dust" on the wheels. Perfect for drilled or slotted brake rotors.
