Thread: Minor issues??
Old Mar 7, 2007 | 01:39 AM
Bostonsrt6's Avatar
Bostonsrt6
Default Re: Minor issues??
Originally Posted by DmnBoy
My SRT has the touching issue - you hear it only when you are backing up with wheels turned sharp - but no damage or issue so no worry!
Nice...Any others. I also noticed when you have the wheel cut all the way too each side...the side that touches when you reverse sticks out further and has a slight tilt...I assume this is normal as well. I found out that you can apply weather strip to the windows as well to reduce wind noise I will keep you guys posted. Any other with the wheel issue rubbing...seems pretty common.
