Originally Posted by victorczx3
Hey Guys !!! Love This Site !!!
I Have Had My Xfire For About 7 Months And I Am Loving Every Minute Of It... I Have A Couple Questions That I Tried Looking In The "search " Mode Of The Site But Maybe Some One Can Answer This Post. I Bought Stock Chromed Rims For This Summer, I Plan To Use The Original Ones For The Track ...But Will The "Tire Pressure" Light Go Off If The Sensor Is Not Present In The Track Set??? Also I Was Thinking About Those Performance Chips They Sell??? Do They Really Work??? Or Are They A Bunch Of Hype??? I Would Love More Power ...But I Will Not Risk Such A Fine Machine Over A $50 Chip ...Has Anyone Installed It With Out Any Problems???
Yes, the light will illuminate while you're using your "track wheels without the sensor", but will go back to normal when you put the other ones back on...
Yes, chip tuning does produce higher hp #'s over the OEM. And if you're thinking that you will pay $50 for an ECU modification, you're sorely mistaken. Think more in the range of $600.
And best
verifiable dyno numbers for ECU mod. on the Crossfire is from Speed Innovations, posted here on this site. But, you're only going to get somewhere in the range of 18-22 hp gain, depending on your engine...
