Originally Posted by etmusic
Hello Infinity,
Thank you for your assistant. I remembered someone in the FORUM saying that its possible to split the signal thats going into the amplifier. Any possibility of me sending the FRONT pre-out and SUB pre-out from the head unit to the factory amplifier? This way i can tune the front and subwoofer separately. Also, do you know where is the crossover for the factory door component speakers? Any idea how much power the factory amplifier are giving out to the front speakers? You reckon the factory amp will be better than the head unit's 50 watt?
Cheers,
Eddy
The input to the factory amp is two channel full range, so to answer your first question, no. Factory crossover is electronically done in the amp for the woofer and the tweeter has a cap on it for its basic crossover...the rest is handled in the amp. Factory amp is 40x6 at 2 ohms so its power is close to the head units.
