Re: Balancing replacement tires
Generally the performance tire is ballanced using lead strip weights that can easily be cut to length or weight and the product is not glued on. The weights have a tape backing just like a strip of duct tape has. To remove them you just peel them off. The centrifugal forces applied to the weights while in use will keep the weights on until the cows come home or until someone removes them.
