Originally Posted by andrew
the easiest way to disable the chime:
begin by moving the drivers seat forward & up as high as possible... the wire is easier to access from the rear of the seat... it is clipped onto the far back side metal seat frame edge under the seat... held in place by 2 metal tab clips... release the clips and you will have nearly a foot of wire to work with. a flash light will aid... carefully cut back the plastic sheathing... 3 wires will be exposed... snip the brown wire and the chime has been eliminated w/o any side effects. tape the wires back up with electrical tape and re-secure with the clips.
I have read this post maybe a good 10 times, but maybe due to either the fact that someone (previous owner) has tampered with the seats, or my lack of english I do not really understand what to do... I moved the seats all the way forward and I have a decent reach inside, but there is no way I can or any human being can reach the clips on the end of the seat... there is a thick cloth wire close to me and a block plastic wire a little further and I can barely see brown red and blue wires exposed and I can reach to snip the brown wire, but I get the impression that there is more than one brown wire so does it matter which one I snip?
