Old Mar 20, 2007 | 12:37 AM
andrew's Avatar
andrew
-C-I-C-C-I Associate Member
Default Re: HOW-TO: Disable the Seatbelt Warning Chime
here are some pics with the drivers seat all the way forward and in its highest position.
2 clips attach to this metal rail...
the circled area is where i cut back the plastic sheathing and sniped the brown wire... needs covered with electrical tape...
the clips (2) that hold this very long wire under the seat are located on the underside metal frame toward the back edge (slip off rail)... remove both clips & you will have 12" of wire to work with. carefully cut back the plastic sheathing and snip the single brown wire (3 wires total)... tape wire with electrical tape and reinstall... you'll realize how simple it is once you do it.
