Old Mar 21, 2007 | 01:32 AM
MMZ_TimeLord's Avatar
MMZ_TimeLord
Default Re: bypass ecm for higher speed
And, by the way... you will not gain that much RPM... the engine is pretty much tached out at the electronic limiter. 158 mph just check and see you are at nearly redline in top gear to hit that speed... you really need to tune the ECU so you get a better power band like SRT6_Crossfire and X'ed. did.
