Old Mar 23, 2007 | 11:20 AM
DmnBoy's Avatar
DmnBoy
Default Re: bypass ecm for higher speed
Originally Posted by Sidez
I don't know of a single person with an SRT-6 that has 425 hp to the ground...
Thus no 200 mph Crossfires...yet!
Also keep in mind the speedo is not accurate (its optimistic) and will get further off the faster you go - Mine is off 3 mph at 60, so it would be off 6-7 at 120, and so on...however if you saw 180 on the speedo, that should still be a respectable 170 ish actual! I believe you will run out of rpm long before...probably by 170 ish.
Just be careful and don't get caught!! I guess then you would have proof of your top speed then, but I know here in oregon speeds like that are a FELONY and end up in immediate jail time!!!
