Originally Posted by andrew
the rubber plugs are placed in the front & rear lower wheel well areas... closest to the lower rocker panel area (kind of up underneath).
i had some pics posted in the past... they are now no longer available for viewing... i will take another set for you later today.
they are intended to keep water from getting inside the frame of the car.
Thanks for the prompt reply.
So now since the vehicle has been driven in the rain, am I to assume water is in the frame, thanks to the dealers ineptness. Would putting it on a ramp allow it to drain before installing plugs? Would requiring the dealer to drain and rustproof be a possible after the fact solution?
