Originally Posted by reformedchevyman
I'm assuming you're looking at interior lights. In that case the answer to your question depends on whether you're running any speakers from the head unit internal amp. Although to be honest, if you want a simple solution, I would just splice the wires for your lights into the cigarette lighter. It has a decent amount of amps and constant voltage.
Yes the cig. lighter is a keyed hot on our cars and would be a better choice than the head unit wiring.
Neon can draw a decent amount of amps.
If you go wit LEDs it doesn't matter as much as the amp draw is very low.
Hope this helps.
