Install Sprint Booster
I read the instructions online. I have the nut cover off, then removed the nut with a 10mm socket. But i couldn't get the washer off. Any trick to getting it off? It said use a magnet, but i couldn't get it off with any magnet i had, i also tried a small flat blade, tape, needle nose pliers. Everything i could think. Well after 30 minutes it got too dark so i had to put it back together. So i guess what i need is exactly what you need to do to remove the washer other than "use a magnet". What shape was it? What did you put it on. Any tips on wiggling the pedal while trying. Everything will help, thanks.
