Thread: my protege 5
Old Apr 20, 2007 | 09:53 PM
MI1XFIRE's Avatar
MI1XFIRE
Default Re: my protege 5
Originally Posted by bluewater87
yep. only thing i've needed to replace are the rear pads and disks. that's not abuse from autox tho, that's from driftin around corners in the snow usin the ebrake. i wore through a brand new set of nexen n3000 (i think they are anyways) tires pretty quick. its a really nice winter drift car when i have it set up right. put the steelies on the front, with the worn down summer rubber on the back, take the 100+ pounds worth of sub and box out, and i'm the new tokyo drifter. haha.
Using the e-brake to lock the rear wheels shouldn't create too much wear on your pads and rotors. Think about it, Its not like you're using the brakes to stop a XXX lbs car at speed. Instantaneous lock up does not generate heat on the rotors on low grip surfaces. I have done this for years with various FWD cars and never had a problem. I replace my rear pads every other time, which is normal for a FWD car...
