Originally Posted by MMZ_TimeLord
I had purchased a wind screen from Chrysler when I had my 2002 Sebring Convertible GTC. It worked like a charm IF the windows were up. Otherwise there was not much difference.
Generally speaking if your windows are up on the freeway and you have a windscreen, you will see a DRASTIC improvement over leaving your windows down without a windscreen.
Granted the Sebring was a much longer car and probably tended to create more turbulence than a Crossfire roadster will. Either way creating what is basically a box without a top is much better than one with 3 open faces (Top and both sides).
Your design is very nice. I like the industrial grade Velcro ("Extreme" as it is marketed).
With the side windows up, does the line of the wind screen come above the windows? If not, then it is probably the perfect height.
I would have never guessed that you could put a wind screen in convertibles that have back seats.
Where did it fit?
Regarding the height. it is close to the same as the side windows. I'm thinking I will lower it to see if it gets better or worse. I'll report back.
