Re: Crossfire autocross build for DS
Originally Posted by ceames94
Great results. You have verified that the car can be competitive in DS competition with the right setup and driving. Did you have any tire clearance problems?
I am having no tire clearance problems at all. The rear 295s still have about an inch clearance on the inside of the wheel well. The front 245/35/18 Hoosiers will clear without a spacer but I am running either a 3mm or a 5mm spacer to ensure no rubbing when the tire deforms under load. I will be getting the front Konis installed this weekend hopefully. I am still awaiting my AMG front sway bar with delrin bushings to arrive. If the car continues to prove competitive at a higher level then I will eventually order a custom set of rear wheels to drop 8-10 lbs of rotating mass per wheel. I also want to add that I installed a stud kit to get rid of the royal pain that is known as lug bolts. This makes the tire swapping so much easier.
