Old Apr 23, 2007 | 09:52 PM
XFireHammer's Avatar
XFireHammer
Default Re: Install Sprint Booster
Again... there is an easier method of installation that was first introduced by "upstate":
All you need is a Phillips screw driver! I've done this myself, and it works!
First remove the screw on the drivers side lower console where the vent is, 1/4 turn; this is a locking screw.
Remove the second Phillips holding the lower drivers side console panel. You'll have to do a little removal manipulation of the panel, but it bends quite easily; its plastic! You may have to depress the gas pedal for clearance and temporary removal.
Note: Always take note of how things fit a feel prior to panel removal, its just a good code to follow.
Get your flashlight, and look back above the Gas Pedal and there is the plug. Squeeze sides to release the locking mechanism, and unplug.
Install SB, make sure connection are secure, re-install lower side console, and finally re-install the vent!
Your Done!
