Old May 1, 2007 | 08:45 AM
  #87 (permalink)
mplc's Avatar
mplc
Default Re: All-in-one FAQ Thread - SpeedInnovation ECU Tuning Info/GBs/Specials
Originally Posted by x'ed
i think at least seven of us have it, and yes that number is easily attainable. the ecu tune and pulleys should get you close, if not the shrick cams will get you there for sure, but they are very expensive. i put down 220 whp or so on a high reading dyno, probably more like a 205 on a more realistic dyno. the pulleys should get you about 212 whp if i had to guess, so you would be close.
Will a pulley upgrade void the warranty? How much are they? Do you recommend one over another?
Thanks...Mike
