Old May 1, 2007 | 12:19 PM
  #95 (permalink)
BRappaport's Avatar
BRappaport
Default Re: Xfire's Best Features
Originally Posted by AMGLover
Didn't see these in the post.
1) speed sensing volume control on stereo.
2) Reset trip odo with engine off. Push odo stalk 2x then hold.
3) Window return on roadster. When retracting the roof if you hold the retract button past the end of cycle beep the windows will return back to the closed position.
4) Change Radio LCD from positive to negative (green w/black to black w/green).
- ej
"Speed sensitive volume control"...I do not think I have this...is this something you can program as a feature? If so...How? Can you actually see the volume db change with speed? If I set my volume to -20db...it stays at that setting...irrespective of my speed...unless I physically turn down the volume.
Ben
