Old May 1, 2007 | 02:32 PM
  #97 (permalink)
BRappaport's Avatar
BRappaport
Default Re: Xfire's Best Features
Originally Posted by AMGLover
You won't see the vol adjust... Beckers have a feature called GAL a speed dependent volume control 0= no volume increase +1 low speed initiation higher number, higher speed before it is initiated xf default is 10 (max is 15) so you will only notice this at highway speeds. It is plug 1 on socket A (bottom most socket).
- ej
Thanks for the reply...I wonder if the radio is connected to the same output on the speed sensor that drives the variable speed control for the windshield wipers?
