Re: Stock HU with Aftermarket Amp
If you are feeding the head unit into the factory amplifier nothing changes ... other than you are sending the factory amp a higher level than original which will mean it will get louder faster and trip the limiters sooner.
If you bypass the amp and use the deck power it will be fine, I run over 100 watts from an off board amp to the factory set with no issues for two years now.
