Originally Posted by intenseblu
...you guys planning on running a seperate gravity fed and pump evacuated oiling system for it or plumb it directly from the main oil system and evacuate with a pump ?.
This won't work unless the evac pump can generate high enough oil pressure to keep things lubed properly. The best bet would be to tap into the engines oiling system. Now I wonder where that might be?
