I have no plans on purchasing or "stealing" a sprint booster.
If I discover that the throttle memory can be programmed to be reset on engine start I will post the info and results.
Then forum members can decide on going with booster from Hong Kong for $250 or a programmed setting for free.
I've done the throttle reset, and all I can say it's not comparing apples to apples to the SB. All the throttle reset does is reset the "Throttle Response" to some default configuration. After you drive for awhile it gets accustomed to your driving habits (Grandma, Moderate, and or Speed Racer) and sets itself to your driving style.
Where as; the SB takes the signal from the original feedback device and resets the gain to a given exponential curve. In essence it simply boost the signal.
Their you go... I will expect 40% of your gross product sales, for giving you the secrets to the "Sprint Booster" when you get your product off to market!
XFH
