Old May 19, 2007 | 01:05 AM
Maxwell's Avatar
Maxwell
Default Re: Another Crossfire entrant into DS autocross
Originally Posted by NoCones
Koni's in and alignment done.
-1.1/-1.2 camber front (without using the camber bolts...yet)
-1.0/-1.5 camber rear
zero toe both ends
if you can get some data on times on this set up that would be cool, I would be curious to see a comparo. on you adjusting the rear toe instead of camber, it will keep the tire flatter in the hard corners and your tires will last a tad longer..
