Old May 21, 2007 | 03:10 PM
HDDP's Avatar
HDDP
Default Re: Another Crossfire entrant into DS autocross
Originally Posted by Sennaspirit
Derek,
Toe out on the front end to resolve plowing issue and push?
I woulda thought that toe in would help the push.
Just wanted to see if you can fill the gaps on how the car is doing with the new setup/wing/other changes. Good luck to you and Nocones!
Senna
Here's a good tech article to keep in your folder...
http://www.tirerack.com/tires/tirete....jsp?techid=58
As far as my car, it's still a PIG and I'm running a few seconds off the pace in my class... Something happened to re-initiate the T/C during my last event and my car bogged down again through nearly every turn, which could account for probably 5 seconds per lap... The wing has slowed my straightaway speeds by 3-5 mph and is lifting the front end at high speed (135+ mph) See picture below from Cal Speedway at top speed... The wing WAS helping in the turns before the stupid T/C re-engaged itself and cut the power again... I was willing to give-up a few MPH on the straights for better handling in the turns...
That being said, I'm still having fun... And really ANNOYED with the T/C.
