Old May 24, 2007 | 02:37 PM
Steve Hellums's Avatar
Steve Hellums
Default Re: Reset computer after oil change?
Originally Posted by spensley
I've changed my oil once, and reset the FSS.
Changing the oil is easy.
Apparently, there's not much room under the car to drain the oil.
Do a search on 'Topsider' or 'draining oil' - that sort of stuff.
There was a post a few days ago - some guy relating his experience.
I don't think you'll read of a bad experience with the topsider.
There's plenty of room under the car, the problem is you have to remove the belly pan to get to the oil plug. I myself would never use the topsider way, you are leaving the sediment and nasty crap in the bottom of your oil pan, but that's just my opinion.
