Old Apr 18, 2004 | 10:43 PM
David Burns's Avatar
David Burns
Default
Originally Posted by crossfiretech
I will not respond anymore. :roll:
I guess you don't know the answer to the question AZ asked three times? Or are you just so ticked he's pissed off at a D/C dealer that you won't answer just to spite him?
AZ...
I did find this bit of advice:
"The 3.2 liter engine uses 8.5 US quarts. It is recommended that only 8 quarts be added initially. Run the engine and check the level. The oil canister/filter can hold about a quart of oil so the level will drop after the oil is circulated for the first time. Add oil as needed." slk32.com
Perhaps the 'grease monkey' put in stated capacity of 8.5, then ran it and saw it drop, so added some more? So know you're reading the 'more'??? Did you try taking a reading with the engine running (as suggested @ slk32.com)??
SeaXFire posted some horrible potentials... eek!
Good luck!
