Old May 28, 2007 | 04:40 PM
Romio's Avatar
Romio
Default Re: Simple Headlight question
There is a metal clip the holds it in. Try on the drivers side first since its easier to see. The clip is a V shape then bends into a hook. The best way I found to unlatch the clip is to put your thumb in between the V and push to the right, it should unlatch and hinge up. Then just pull the plug out from the light then grab the back of the light and it should come out without much force.
